[gdal-dev] KML : some vectors are not seen by GDAL
Bugbuster philippe.ghesquiere at airbus.com
Thu May 11 05:04:46 PDT 2017
Dear all,When I try to export some vector data in KML, I sometimes "lose"
some vectors.It depends on the way layers are created :case #1 : no  tags
are created. All vectors are considered "at the top level". Everything is
finecase #2 : vectors all belong to a specific layer, using one or several
tags. Everything is still finecase #3 : some vectors do not belong to a
specific layer. Others belong to specific layers.The "top level" vectors are
not seen by GDAL (not displayed in QGIS either). However, they are displayed
in Google Earth.The KML file looks like :      snafu    ...       <-- Not
seen by ogrinfo          ...     <-- OK    My environment : Windows 8 64
bits, Gdal 2.0.2, using LIBKML plugin.Do you have any ideas ?ThanksPhilippe
View this message in context: http://osgeo-org.1560.x6.nabble.com/KML-some-vectors-are-not-seen-by-GDAL-tp5320170.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170511/a81b465b/attachment.html>
