[gdal-dev] error reading AIG blocks
Gregory, Matthew matt.gregory at oregonstate.edu
Fri May 12 09:57:51 PDT 2017
Even Rouault wrote:
> Thanks for the report. I've fixed the issue per
> https://trac.osgeo.org/gdal/ticket/6886
> AIG relies on rollover on addition of big negative values,
> which is undefined behaviour in C. Interesting...
> Can the test dataset be integrated in the GDAL test suite ?
> (probably in http://download.osgeo.org/gdal/data/aig/ )
Even,
Thanks for the very fast fix.  Please feel free to use the dataset in the test suite.
thanks, matt
