[gdal-dev] GDAL build without big tiff support
Even Rouault even.rouault at spatialys.com
Tue May 16 00:30:14 PDT 2017
On mardi 16 mai 2017 01:27:15 CEST Dmitry Baryshnikov wrote:
> Hi,
> it seem to me there is misprint here:
> https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/gtiff/geotiff.cpp#L16195
> instead of
>  > else if( nCompression == COMPRESSION_JPEG
> should be
>  > else if( l_nCompression == COMPRESSION_JPEG
Indeed. Fixed per https://trac.osgeo.org/gdal/ticket/6890
As you may guess, this configuration hasn't been tested in a while at runtime too.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170516/b72737fa/attachment.html>
