[gdal-dev] ogr2ogr PROMOTE_TO_MULTI with linestrings?
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 16 06:21:06 PDT 2017
I'm just trying to load the census roads data. I think what happened is
that when the table was created using -nlt PROMOTE_TO_MULTI it was
created as polygon geometry. then the subsequent insert failed. I change
the script to -nlt MULTILINESTRING and it loaded all the data. I found a
post from Even circa 2012 IIRC that indicated PROMOTE_TO_MULTI should
work for both polygons and linestrings.
I just checked the log file and the table was created with:
ogr2ogr -t_srs EPSG:4326 -nln census.roads -nlt PROMOTE_TO_MULTI -f
PostgreSQL -overwrite -lco OVERWRITE=YES -lco PRECISION=NO -lco
GEOMETRY_NAME=geom -lco FID=gid "PG:dbname=buildings host=localhost
port=5432 user=postgres active_schema=census"
/u/ror/buildings/data/census/tmp-11/tl_2016_us_county.shp
and then failed on the first insert:
PostgreSQL -append "PG:dbname=buildings host=localhost port=5432
/u/ror/buildings/data/census/tmp-11/tl_2016_06001_roads.shp
Warning 1: Geometry to be inserted is of type Multi Line String, whereas
the layer geometry type is Multi Polygon.
Insertion is likely to fail
ERROR 1: ERROR:  Geometry type (MultiLineString) does not match column
type (MultiPolygon)
ERROR 1: INSERT command for new feature failed.
When I changed, PROMOTE_TO_MULTI to MULTILINESTRING, everything worked
fine. I only loaded one state (CA), but I do know for a fact that some
of the Census roads data has a mix of Linestring and MultiLinestring
features, which is why I used PROMOTE_TO_MULTI in the first place.
-Steve
On 5/16/2017 2:58 AM, jratike80 wrote:
> Stephen Woodbridge wrote
>> On 5/15/2017 6:15 PM, Stephen Woodbridge wrote:
>>> Hi,
>>> I'm trying to load both polygons and linestrings and would like
>>> PROMOTE_TO_MULTI to work for both, but it appears to define Multipolygon
>>> type and does not work for linestrings/multilinestrings.
>>> Maybe it would make more sense to have:
>>> PROMOTE_TO_MULTI - work for either polygon or linestring depending on
>>> what the first object is
>>> or have two options like:
>>> PROMOTE_POLY_TO_MULTI
>>> PROMOTE_LINE_TO_MULTI
>>> Or maybe, I'm totally missing something in the docs.
>> Sorry, forgot to add:
>> ogrinfo --version
>> GDAL 2.1.0, released 2016/04/25
>> PostgreSQL -append PG:dbname=buildings host=localhost port=5432
>> /u/ror/buildings/data/census/tmp-11/tl_2016_06061_roads.shp
>> type (MultiPolygon)
> Hi,
> Please tell more details about what you plan to do. Shapefile can't contain
> a mixture of lines and polygons so the error you get must mean that PostGIS
> table "census.roads" already exists and it has been created as MultiPolygon.
> Did you convert some polygons from another shapefile into the same table
> before? Anyway the restriction is at this stage set by PostGIS which
> requires multipolygons and you just can't  convert your lines into
> multipolygons.
> Drop your table and start again by using -nlt GEOMETRY and you should be
> fine. That makes the PostGIS table to accept any kind of geometries. If you
> definitely need a mixture of MULTIpolygons and MULTIlinestrins we must add
> casts somewhere but perhaps that is not what you really want.
> -Jukka Rahkonen-
> View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-ogr2ogr-PROMOTE-TO-MULTI-with-linestrings-tp5320602p5320626.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
