[gdal-dev] Resizing CPLErrorContext?
Even Rouault even.rouault at spatialys.com
Tue May 16 11:01:06 PDT 2017
On mardi 16 mai 2017 10:26:09 CEST Kurt Schwehr wrote:
> I now know this is referred to as the "struct hack."
> This really is undefined behavior in the C++11 standard...
Well, I don't think the hack is really needed and char szLastErrorMsg[] could be
replaces by a char* pszLastErrorMsg that would be malloc'ated.
The current situation comes from the fact that originally no custom free function
could be associated with a TLS member, but now that we have a
CPLSetTLSWithFreeFunc() we could use it to free the pszLastErrorMsg member
before freeing the context.
(or use std::string if you prefer, but this code portion can be run under very low
memory conditions, so great care is needed)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170516/c1475aa5/attachment-0001.html>
