[gdal-dev] MrSID Color Spaces
Martin Chapman mchapman at hyperacktive.com
Wed May 17 07:26:00 PDT 2017
Nicolas,
Looks good bud!  Thanks!
Best regards,
Martin
From: SIMON Nicolas [mailto:nicolas.simon at spw.wallonie.be]
Sent: Wednesday, May 17, 2017 4:41 AM
To: Martin Chapman
Cc: gdal-dev at lists.osgeo.org; Even Rouault
Subject: RE: [gdal-dev] MrSID Color Spaces
Martin,
Could you test this patch ?
Nicolas
De : gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Even
Rouault
Envoyé : mardi 16 mai 2017 18:28
À : Martin Chapman
Cc : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] MrSID Color Spaces
On mardi 16 mai 2017 10:13:52 CEST Martin Chapman wrote:
> Even or Frank or whoever it may concern,
> Not a big deal but I was trying to open a JP2 file using the MrSID driver
> and noticed that the mrsiddataset.cpp does not identify the color spaces
> MRSID_LTI_COLORSPACE_GRAYSCALEA and MRSID_LTI_COLORSPACE_GRAYSCALEA_PM
> configurations in the MrSIDRasterBand() constructor. I happen to have a
two
> band JP2 that is a grayscale image with an alpha channel. The color
> interpretation comes back as GCI_undefined. Not that important but if you
> ever feel like fixing it, that would be nice.
> The fix would go somewhere close to line 485 in mrsiddataset.cpp.
Basically
> just need to add a couple of more case statements in the switch statement.
Martin,
Seems you are closed to a patch. Can you provide it ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170517/278b1443/attachment.html>
