[gdal-dev] Cannot load Java GDAL native library in web application with error in link library?
yuchan a09550 at gmail.com
Tue May 23 06:22:26 PDT 2017
Thanks Ian,
However, we want to deploy this application in other kinds of web
application not only Tomcat so it is really complicated to have to modify
Tomcat.
I also tried to set LD_LIBRARY_PATH=/usr/lib/java/gdal/:$LD_LIBRARY_PATH in
~/.bashrc and then execute it with source ~/.bashrc where I can see the
LIBRARY_PATH environment variable in console, restart Tomcat 7 and it still
shows the error
Handler dispatch failed; nested exception is java.lang.UnsatisfiedLinkError:
org.gdal.osr.osrJNI.new_SpatialReference__SWIG_1()J. Please check the log
for the detail error.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-load-Java-GDAL-native-library-in-web-application-with-error-in-link-library-tp5321448p5321455.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
