[gdal-dev] Cannot load Java GDAL native library in web application with error in link library?
yuchan a09550 at gmail.com
Tue May 23 06:46:41 PDT 2017
Unfortunately, Tomcat runs in same computer, user which I set the environment
variable, so I still need to find out a way for making GDAL can run in web
application in Java.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-load-Java-GDAL-native-library-in-web-application-with-error-in-link-library-tp5321448p5321462.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
