[gdal-dev] compressed GTiff large file size?
Even Rouault even.rouault at spatialys.com
Tue May 30 11:52:55 PDT 2017
On mardi 30 mai 2017 17:44:18 CEST MUTLU OZDOGAN wrote:
> Dear Developers
> I have two multi-band geotiff files (each about 2 GB in size uncompressed)
> that I would like to mosaic using gdal_merge.py.  These files make up two
> halves of a single Landsat footprint so when joined should create a single
> mosaicked image.  I checked the corner coordinates and they seem correct.
> However, when I use the gdal_merge.py command with the -co “COMPRESS=LZW”
> option, the final file size ends up being a ~100 GB which does not make any
> sense.  Any ideas about what is going on?  I checked the image dimensions
> and they seem to be correct and should result in a file that is about 4.5
> GB in size uncompressed so the compressed version should be at least this
> size if not smaller.
Mutlu,
Asy you noticed, gdal_merge.py strategy is not necessarily optimal regarding minimizing file
size in case of compression
So I'd recommend using a workflow like :
gdalbuildvrt tmp.vrt landsat1 landsat2
gdal_translate tmp.vrt merged.tif -co COMPRESS=LZW -co TILED=YES
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170530/ae85cfc3/attachment.html>
