[gdal-dev] WCS 2.0, getting (multidimensional) data
Peter Baumann p.baumann at jacobs-university.de
Fri Nov 3 01:54:28 PDT 2017
On 11/03/2017 08:57 AM, Ari Jolma wrote:
> I have two things that I need to ask/discuss regarding WCS 2.0
> 1) My understanding is that there are potentially three CRS in operation: the
> CRS of the bbox of the coverage (the native CRS of the server); the CRS of the
> grid; and the CRS where the user wants the data. I can imagine that it is
> perfectly possible for a server to advertise data from an area bounded by
> geographic coordinates, and that the data is in some specific projected
> coordinate system. Also, the data could be regular but not east-north (it is
> rotated for example). This would be described in a CoverageDescription.
> Despite the rotation, GDAL would show the data east-nort (without rotation),
> since only the bbox of the coverage is given.
> Again, it is perfectly possible that the user wants the data in some CRS that
> is not the native CRS of the WCS. The GetCoverage request can contain an
> instruction for the server to serve the data in the CRS the user wants the
> data (this is an extension in 2.0). User can set this (it must be one of those
> supported by the server)
that is correct, Ari
> in the dataset definition (WCS_GDAL XML). Thus GDAL needs to show the coverage
> bbox to its users in that CRS.
no, it's just one bbox; WGS84 is common. Otherwise you'd have to advertise
sometimes thousands of bbox variants, which is not feasible.
-Peter
> And, as above, the GeoTransform is east-north.
> Is this correct analysis?
> BTW, the coordinate transformation of the bbox is not done in WCS driver at
> the moment in the case of user CRS != server native CRS.
> 2) WCS can offer multidimensional data with complex data records. I want the
> GDAL user to have a control on how the data is organized into (current) GDAL.
> For example the server may offer spatio-temporal (x/y/t) data with about wave
> heights in a sea (to link this to what I'm getting paid for now :)) that are
> described as average and max. Obviously I want x/y bands, but I may want
> either the temporal data or the wave height data into bands, depending on the
> application. The workflow would go
> 1. gdalinfo to the server, see this data as a layer with name
> "VHM0_year_meanmax", gdalinfo reports that layer as a subdataset
> 2. gdalinfo into the layer, now it reports that there is an additional
> dimension (t) and that the datarecord consists of two values mean and max; it
> also reports information about the time (begin, end, step)
> 3. I decide to use a specific time and start using datasets with two bands
> (mean and max)
> I have such data as NetCDF and I don't think I can follow that workflow with
> it since the driver puts the mean and max wave heights right away into
> subdatasets and time into bands.
> In the WCS there could/should be a similar default behavior but that should be
> changeable by options (-oo t=some_timestamp).
> Thoughts?
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Peter Baumann
 - Professor of Computer Science, Jacobs University Bremen
   www.faculty.jacobs-university.de/pbaumann
   mail: p.baumann at jacobs-university.de
   tel: +49-421-200-3178, fax: +49-421-200-493178
 - Executive Director, rasdaman GmbH Bremen (HRB 26793)
   www.rasdaman.com, mail: baumann at rasdaman.com
   tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
