[gdal-dev] WCS 2.0, getting (multidimensional) data
Even Rouault even.rouault at spatialys.com
Fri Nov 3 02:38:56 PDT 2017
> Another thing, the raster size. Since the real raster, whose size is
> given in GridEnvelope in CoverageDescription, may be rotated relative to
> the GDAL dataset, the GDAL dataset size is in general case not the size
> of the real raster. It's just a computation but the result is that the
> size of the WCS dataset raster may be an approximation.
Ah, i think I see your point
If the grid offsetVector express a rotation. WCSParseGMLCoverage() currently  expose
as dimension the value of limits.GridEnvelope.high[] - limits.GridEnvelope.low[] + 1 and
the offsetVector's in the geotransform. So this is consistant.
But when you do a RasterIO() request which translates to a WCS GetCoverage request
you express a BBOX, and not something in grid/image coordinates. Wondering what kind
of response a server would return then... Would it be a "straigth" grid our would it keep
the rotation exposed in the CoverageDescription
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171103/ca43ecf8/attachment.html>
