[gdal-dev] WCS 2.0, getting (multidimensional) data
Peter Baumann p.baumann at jacobs-university.de
Tue Nov 7 06:29:42 PST 2017
Ari-
On 11/07/2017 09:56 AM, Ari Jolma wrote:
> Thanks for the replies before. I believe I'm getting closer, but slowly.
> In my earlier question I was referring to three CRSs. I now believe that it is
> only two since I had overlooked requirement 23, which to my understanding
> requires that the CRS of the coverage (top level boundedBy element) is the
> same as the CRS of the grid (in domainSet element). Thus GDAL can and should
> set the dataset size and geotransform by what's in domainSet and there's no
> such ambiguity in the grid size as I thought.
> To get multidimensional data into GDAL 2D domain, one may need to slice the
> data at some point in the non x/y dimensions. I'm testing this with the
> Rasdaman server. My code currently creates a KVP
> "SUBSET=unix(2008-01-08T00:02:58.000Z)" in an attempt to slice the time
> dimension. The whole test URL is
> http://ows.rasdaman.org/rasdaman/ows?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&COVERAGEID=test_irr_cube_2&FORMAT=application%2Foctet-stream&SUBSET=E(75042.7273594,95042.7273593873)&SUBSET=N(5434865.55794,5454865.55794)&SUBSET=unix(2008-01-08T00:02:58.000Z)&RANGESUBSET=b1
> which replies
> Trimming subset in WCS must follow this syntax 'lowerBound,upperBound', given
> '2008-01-08T00:02:58.000Z'.
did you try putting the time string in double quotes? As the string can have any
syntax it needs to be escaped.
> I don't understand why. I'm trying to slice, not trim. I don't know of other
> servers serving >2D data so I can't test with other brands.
syntactically, you are slicing because you have only one time coordinate;
trimming needs lower + upper bound.
-Peter
> With a MapServer instance I have a problem setting the rangesubset, it does
> not seem to work with field names, only indexes.
> http://194.66.252.155/cgi-bin/BGS_EMODnet_bathymetry/ows?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&COVERAGEID=BGS_EMODNET_CentralMed-MCol&FORMAT=image%2Ftiff&SUBSET=long(9.83125,9.83958334)&SUBSET=lat(46.18124999,46.18958333)&RANGESUBSET=band1
> does not work although band1 is given as name in coverage description, but
> http://194.66.252.155/cgi-bin/BGS_EMODnet_bathymetry/ows?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&COVERAGEID=BGS_EMODNET_CentralMed-MCol&FORMAT=image%2Ftiff&SUBSET=long(9.83125,9.83958334)&SUBSET=lat(46.18124999,46.18958333)&RANGESUBSET=1
> works.
> Ari
> Ari Jolma kirjoitti 03.11.2017 klo 09:57:
>> I have two things that I need to ask/discuss regarding WCS 2.0
>> 1) My understanding is that there are potentially three CRS in operation: the
>> CRS of the bbox of the coverage (the native CRS of the server); the CRS of
>> the grid; and the CRS where the user wants the data. I can imagine that it is
>> perfectly possible for a server to advertise data from an area bounded by
>> geographic coordinates, and that the data is in some specific projected
>> coordinate system. Also, the data could be regular but not east-north (it is
>> rotated for example). This would be described in a CoverageDescription.
>> Despite the rotation, GDAL would show the data east-nort (without rotation),
>> since only the bbox of the coverage is given.
>> Again, it is perfectly possible that the user wants the data in some CRS that
>> is not the native CRS of the WCS. The GetCoverage request can contain an
>> instruction for the server to serve the data in the CRS the user wants the
>> data (this is an extension in 2.0). User can set this (it must be one of
>> those supported by the server) in the dataset definition (WCS_GDAL XML). Thus
>> GDAL needs to show the coverage bbox to its users in that CRS. And, as above,
>> the GeoTransform is east-north.
>> Is this correct analysis?
>> BTW, the coordinate transformation of the bbox is not done in WCS driver at
>> the moment in the case of user CRS != server native CRS.
>> 2) WCS can offer multidimensional data with complex data records. I want the
>> GDAL user to have a control on how the data is organized into (current) GDAL.
>> For example the server may offer spatio-temporal (x/y/t) data with about wave
>> heights in a sea (to link this to what I'm getting paid for now :)) that are
>> described as average and max. Obviously I want x/y bands, but I may want
>> either the temporal data or the wave height data into bands, depending on the
>> application. The workflow would go
>> 1. gdalinfo to the server, see this data as a layer with name
>> "VHM0_year_meanmax", gdalinfo reports that layer as a subdataset
>> 2. gdalinfo into the layer, now it reports that there is an additional
>> dimension (t) and that the datarecord consists of two values mean and max; it
>> also reports information about the time (begin, end, step)
>> 3. I decide to use a specific time and start using datasets with two bands
>> (mean and max)
>> I have such data as NetCDF and I don't think I can follow that workflow with
>> it since the driver puts the mean and max wave heights right away into
>> subdatasets and time into bands.
>> In the WCS there could/should be a similar default behavior but that should
>> be changeable by options (-oo t=some_timestamp).
>> Thoughts?
>> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Peter Baumann
 - Professor of Computer Science, Jacobs University Bremen
   www.faculty.jacobs-university.de/pbaumann
   mail: p.baumann at jacobs-university.de
   tel: +49-421-200-3178, fax: +49-421-200-493178
 - Executive Director, rasdaman GmbH Bremen (HRB 26793)
   www.rasdaman.com, mail: baumann at rasdaman.com
   tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
