[gdal-dev] [gdal 2.2.2] different result with gdal 2.1.0
Even Rouault even.rouault at spatialys.com
Tue Nov 7 13:30:43 PST 2017
Vincent,
digging into the GDAL 2.2.0 NEWS file, I see:
ASRP driver:
 * fix georeferencing of polar arc zone images (#6560)
So if there's an issue it is mostly related to that change, rather than on the gdalwarp /
GDALSuggestedWarpOutput side of things
And that fix was backported to GDAL 2.1.1, which explains I saw same results in the latest
state of GDAL 2.1, 2.2 and trunk branchs, if you are on GDAL 2.1.0 which has not this fix
You should already see the difference of georeferencing between GDAL 2.1.0 and later
version by doing a gdalinfo on the source ASRP file.
Do you have strong reasons to believe that GDAL 2.1.0 was really georeferencing
correctly your dataset ?
The change done in https://trac.osgeo.org/gdal/ticket/6560 seems at first sight to be an
improvement regarding the previous behaviour
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171107/cfb38aff/attachment.html>
