[gdal-dev] _gdal.FillNodata not Python function
Even Rouault even.rouault at spatialys.com
Wed Nov 8 02:35:23 PST 2017
Gabriel,
> > I'm working with Python 3.6 32bits, GDAL package
> > (GDAL‑2.2.2‑cp36‑cp36m‑win32.whl) i've installed from here :
> > https://www.lfd.uci.edu/~gohlke/pythonlibs/
I don't have experience regarding those binaries.
> > I also installed the gdal-202-1800-core.msi from here :
> > http://www.gisinternals.com/query.html?content=filelist&file=release-1800-
> > gdal-2-2-1-mapserver-7-0-6.zip
> > Here is the error I get when I try the fillnodata python utility :
> > gdal_fillnodata -md 2 myImage.tif myImage_correction.tif
> > Traceback (most recent call last):
> >   File "C:\Python36\Scripts\gdal_fillnodata.py", line 197, in <module>
> >     callback = prog_func )
> >   File "C:\Python36\lib\site-packages\osgeo\gdal.py", line 2742, in
> > FillNodata
> >     return _gdal.FillNodata(*args, **kwargs)
> > RuntimeError: Object given is not a Python function
> > Do you have any idea how to fix it ? Maybe wrong installation ?...
> > Thanks !
For what is worth, I've downloaded and installed:
http://download.gisinternals.com/sdk/downloads/release-1800-gdal-2-2-1-mapserver-7-0-6.zip
http://download.gisinternals.com/sdk/downloads/release-1800-gdal-2-2-1-mapserver-7-0-6/GDAL-2.2.1.win32-py3.4.msi
https://www.python.org/ftp/python/3.4.3/python-3.4.3.msi
and a common line similar to yours work fine.
So I suspect the issue is with the Python stuff from GDAL‑2.2.2‑cp36‑cp36m‑win32.whl , and using it
with the native lib provided by gisinternals will not help. But as shown above, if you use
the Python package provided by gisinternals, that should work.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171108/ccab025b/attachment.html>
