[gdal-dev] Extracting keys & values from OSM Planet
    Nikos Alexandris
    nik at nikosalexandris.net
    Wed Nov  8 02:38:18 PST 2017
Frank Broniewski:
>Hi Nikos,
>I am using a similar approach to yours to extract data from OSM files
>to a GIS format. I chose Spatiallite as a format since it is superior
>to the Shapefile format in all areas.  FYI here’s what I do:
>osmconvert -b="5.5,49,8,50.5" -o=saarland.osm.pbf "europe-latest.osm.pbf"
>ogr2ogr --config OSM_CONFIG_FILE /home/frank/gdal/osmconf.ini -f SQLite -dsco SPATIALITE=YES -progress -gt 65536 -t_srs "EPSG:31466" >/tmp/saarland.sqlite /tmp/saarland.osm.pbf
>Please note the “–config” switch for a custom osmconf.ini. With that
>you can copy the config to a custom location and have several configs
>for many use cases.
Thank you Even and Frank!
I will likely adopt the `osmconf.ini` method.
@Frank, I would go a step further if time permits. A function or script that
takes something like `layer=lines` and
`keys="track,footway,bridleway,path"` as input parameters and outputs the
custom configuration file.
From reading the driver's manual [0], there is a hint about the spatial,
filtering resulting in lines or polygons missing vertices. Is this a/the
reason, to stick to `osmconvert` for extracting areas of interest?
Thank you for your (invaluable) time, Nikos
[0] http://www.gdal.org/drv_osm.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171108/18fcf3db/attachment.sig>
