[gdal-dev] Call for discussion on RFC 70: Guessing output format from output file name extension
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 10 01:34:33 PST 2017
mj10777 wrote
> Reading the Magic-Header signatures first and then guessing from the file
> extension may be a better approach.
The title says "Guessing output format from output file name extension",
like in
ogr2ogr output.gpkg input.shp
Where would you read the Magic-Headers in this case?
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
