[gdal-dev] transformation failure from WGS 84 to GRS 1980
Saulteau Don sault.don at gmail.com
Fri Nov 10 23:45:36 PST 2017
I'm running Arch Linux :)
On Nov 10, 2017 01:08, "Andre Joost" <andre+joost at nurfuerspam.de> wrote:
> Am 09.11.2017 um 20:52 schrieb Donovan Cameron:
>> Afternoon!
>> I recently upgraded to gdal 2.2.2 from 2.1 on linux and when I try to
>> use ogr2ogr to append/update an existing table in PostgreSQL/PostGIS the
>> command fails because it can't apply a transformation.
>> The command works fine in gdal 2.1.
> Where did you get gdal 2.2.2 from? I don't see it in any Ubuntu or
> Ubuntugis package.
> Greetings,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171111/e23c9e1d/attachment.html>
