[gdal-dev] Cannot build for iOS due to GUInt64 error
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Nov 13 13:30:21 PST 2017
Hi Nik,
You may try alternative build scenario using CMake.
1.  Install XCode command line tools if already not done this
(https://www.embarcadero.com/starthere/xe5/mobdevsetup/ios/en/installing_the_commandline_tools.html)
and CMake (https://cmake.org/download/)
2. In terminal execute commands:
 > git clone --depth 1 https://github.com/nextgis-borsch/lib_gdal.git
 > cd lib_gdal
 > mkdir build
 > cd build
 > cmake -G"Unix Makefiles" -DBUILD_TARGET_PLATFORM=IOS
-DCMAKE_INSTALL_PREFIX=install -DCMAKE_BUILD_TYPE=Release
-DENABLE_BITCODE=OFF -DIOS_ARCH=arm64 -DIOS_PLATFORM=OS -DENABLE_NEON=ON
-DCMAKE_TOOLCHAIN_FILE=../cmake/ios.toolchain.cmake -DWITH_JSONC=ON
-DWITH_JSONC_EXTERNAL=ON -DWITH_TIFF=ON -DWITH_TIFF_EXTERNAL=ON
-DWITH_GeoTIFF=ON -DWITH_GeoTIFF_EXTERNAL=ON -DOSX_FRAMEWORK=ON
-DENABLE_GIF=OFF -DENABLE_CAD=OFF -DENABLE_PNG=OFF -DGDAL_BUILD_APPS=OFF
-DGDAL_BUILD_DOCS=OFF -DWITH_PYTHON=OFF ..
Some flags description:
-DIOS_ARCH maybe armv7, armv7s, arm64, i386 or x86_64
-DIOS_PLATFORM maybe IOS or SIMULATOR
After configuring you will see summary about GDAL build or error
message. I expect everything will be fine.
Run this command to build GDAL:
 > cmake --build . -- -j 4
May be this need to rerun twice as dependency may not build on first run.
You may build GDAL for several architectures and create fat library
using lipo -create command (I rewrite OpenCV py script to automate
creating my own fat iOS library which use GDAL -
https://github.com/nextgis/nextgis_datastore/blob/master/opt/ios/build_framework.py)
This is minimal build of GDAL. If you need some drivers which not build
by listed command let me know - I'll help to modify command line options.
Best regards,
     Dmitry
13.11.2017 23:30, Nik Sands пишет:
> Hi Even,
> If I include the -Wall option, then I do get just the one warning.  Here’s the command line I’m using, which is based on similar command lines from the make output…
> $ /Applications/Xcode.app/Contents/Developer/usr/bin/gcc -o conftest -arch arm64 -pipe -Os -gdwarf-2 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS11.1.sdk -Wno-implicit-function-declaration -fembed-bitcode -mno-thumb -Wall  -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS11.1.sdk conftest.c -ldl
> conftest.c:1:24: warning: unused variable 'off' [-Wunused-variable]
> int main() { long long off=0; }
> 1 warning generated.
> I made the change you suggested to acinclude.m4 and then ran autoconf.  Then I attempted to build GDAL again, but got the same error:
> geotiff.cpp:7653:13: error: unknown type name 'GUInt64'
>      typedef GUInt64 WordType;
> 1 error generated.
> make[2]: *** [../o/geotiff.lo] Error 1
> make[1]: *** [gtiff-install-obj] Error 2
> make: *** [frmts-target] Error 2
> I have to admit that I’m a very small-time developer and I’m somewhat out of my depth here, so forgive me if I sound like I don’t understand some of this stuff.
> Cheers,
> Nik.
>> On 12 Nov 2017, at 11:22 pm, Even Rouault <even.rouault at spatialys.com> wrote:
>> On dimanche 12 novembre 2017 19:50:47 CET Nik Sands wrote:
>>> Hi Even,
>>> Thanks for your reply.  You are correct as usual.  Your ‘cc’ test produced
>>> no errors,
>> And no warnings as well ?
>> Weird, since this is the test that is used to dected long long presence
>> See m4/acinclude.m4
>> Do you run configure with CCFLAGS defined ? For example, if CCFLAGS="-Wall", then the test will throw a warning that will make it fail.
>> I'm not sure why we use CCFLAGS in that file, whereas CFLAGS is used everywhere else.
>> What if you change in m4/acinclude.m4
>>    echo 'int main() { long long off=0; }' >> conftest.c
>> to
>>    echo 'int main() { long long off=0; (void)off; return 0; }' > conftest.c
>> and run autoconf to regenerate configure ?
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com <http://www.spatialys.com/>
> NIK SANDS
> Line Tamer | Time Traveller | Space Cadet
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171114/e3e87c3c/attachment-0001.html>
