[gdal-dev] Cannot build for iOS due to GUInt64 error
Nik Sands nik at nixanz.com
Mon Nov 13 16:19:47 PST 2017
No output at all (no errors, no warnings) for that test.
Cheers,
Nik.
(PS.  Re-sent to include the list address)
NIK SANDS
Line Tamer | Time Traveller | Space Cadet
----- Original Message -----
 "Even Rouault" <even.rouault at spatialys.com>
To:
"Nik Sands" <nik at nixanz.com>
Cc:
<gdal-dev at lists.osgeo.org>
Sent:
Mon, 13 Nov 2017 21:40:32 +0100
Subject:
Re: [gdal-dev] Cannot build for iOS due to GUInt64 error
	On mardi 14 novembre 2017 07:30:14 CET Nik Sands wrote:
	> Hi Even,
	> If I include the -Wall option, then I do get just the one warning.
Here’s
	> the command line I’m using, which is based on similar command
lines from
	> the make output…
	> $ /Applications/Xcode.app/Contents/Developer/usr/bin/gcc -o
conftest -arch
	> arm64 -pipe -Os -gdwarf-2 -isysroot
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Deve
	> loper/SDKs/iPhoneOS11.1.sdk -Wno-implicit-function-declaration
	> -fembed-bitcode -mno-thumb -Wall -arch arm64 -isysroot
	> loper/SDKs/iPhoneOS11.1.sdk conftest.c -ldl conftest.c:1:24:
warning: unused
	> variable 'off' [-Wunused-variable] int main() { long long off=0; }
	> 1 warning generated.
	And what does the above return if you do it on the following
conftest.c:
	int main() { long long off=0; (void)off; return 0; }
	http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171114/fe4c37e4/attachment.html>
