[gdal-dev] Fwd: RE: [gdal 2.2.2] different result with gdal 2.1.0
Even Rouault even.rouault at spatialys.com
Tue Nov 14 02:23:54 PST 2017
CC'ing Vincent's latest answer
----------  Forwarded Message  ----------
Subject: RE: [gdal-dev] [gdal 2.2.2] different result with gdal 2.1.0
Date: mardi 14 novembre 2017, 10:04:51 CET
From: Vincent BERNAT <vincent.bernat at magellium.fr>
To: Even Rouault <even.rouault at spatialys.com>
Even,
Thanks for your reply.
In fact, you were right : my dataset was wrongly georeferencing and with gdal 2.2.2, it's ok.
I am sorry for the mistake!
Thanks again
Regards,
Vincent
De : Even Rouault <even.rouault at spatialys.com>
Envoyé : mardi 7 novembre 2017 22:30
À : Vincent BERNAT
Cc : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] [gdal 2.2.2] different result with gdal 2.1.0
Vincent,
digging into the GDAL 2.2.0 NEWS file, I see:
ASRP driver:
* fix georeferencing of polar arc zone images (#6560)
So if there's an issue it is mostly related to that change, rather than on the gdalwarp /
GDALSuggestedWarpOutput side of things
And that fix was backported to GDAL 2.1.1, which explains I saw same results in the latest
state of GDAL 2.1, 2.2 and trunk branchs, if you are on GDAL 2.1.0 which has not this fix
You should already see the difference of georeferencing between GDAL 2.1.0 and later
version by doing a gdalinfo on the source ASRP file.
Do you have strong reasons to believe that GDAL 2.1.0 was really georeferencing correctly
your dataset ?
The change done in https://trac.osgeo.org/gdal/ticket/6560 seems at first sight to be an
improvement regarding the previous behaviour
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171114/88346ef1/attachment.html>
