[gdal-dev] WCS driver work
Ari Jolma ari.jolma at gmail.com
Tue Nov 14 07:41:16 PST 2017
I've got very close to being able to get valid data (visual comparison
in QGIS) from various server types and WCS versions.
I've documented the results here:
https://trac.osgeo.org/gdal/wiki/WCS%2Binteroperability
It seems that I need eight option flags to cover all cases. Mostly the
problems are with CRS that have inverted axis order. Also it seems to be
a problem if the server or the standard does not support requesting
directly tiles of specific size. It is especially a problem since GDAL
fails the call if the size is not expected.
The only combination that I have not yet managed to get to work is
GeoServer with version 1.1 and inverted axis order. I can get a decent
response but the returned geotiff has slightly wrong size (59x38 instead
of 60x38). The problematic call is below[1].
Also, I have/know only a few servers and I lack some combinations; I've
also found a server with a combination that I've managed to test ok, but
whose behavior I can't yet explain[2].
I'm writing documentation and test code but the latter will still take
some time to be ready for the trunk.
The code is at https://github.com/ajolma/gdal/tree/trunk/gdal/frmts/wcs
I've also made one ticket regarding port code
https://trac.osgeo.org/gdal/ticket/7141
Ari
[1]
https://msp.smartsea.fmi.fi/geoserver/wcs?SERVICE=WCS&VERSION=1.1.0&REQUEST=GetCoverage&IDENTIFIER=smartsea%3Aeusm2016-EPSG2393&FORMAT=image%2Ftiff&BOUNDINGBOX=6620001.14539506,3199988.18514013,6670001.21326246,3279980.29051582,urn:ogc:def:crs:EPSG::2393&RangeSubset=contents&GridBaseCRS=urn:ogc:def:crs:EPSG::2393&GridCS=urn:ogc:def:cs:OGC:0.0:Grid2dSquareCS&GridType=urn:ogc:def:method:WCS:1.1:2dGridIn2dCrs&GridOrigin=6670001.21326246,3199988.18514013&GridOffsets=0,1333.20175626157,-1315.79125966838,0
[2]
https://lists.osgeo.org/pipermail/mapserver-users/2017-November/080339.html
