[gdal-dev] GDAL 2.2.3 planning
Markus Neteler neteler at osgeo.org
Sat Nov 18 08:01:00 PST 2017
Hi Even,
On Fri, Nov 17, 2017 at 11:59 AM, Sebastiaan Couwenberg
<sebastic at xs4all.nl> wrote:
> On 11/17/2017 11:58 AM, Martin Landa wrote:
>> Hi,
>> 2017-11-17 9:58 GMT+01:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
>>> Has the gdal-grass plugin been updated to support 7.4? Or are there no
>>> new libraries that need to be linked like last time? [0]
>>> [0] https://trac.osgeo.org/gdal/ticket/6785
>> I tried to compile plugin against GRASS 7.4, no problem appeared. Ma
> Compiling wasn't the issue last time, it only showed at runtime.
Configuration works also here but I didn't try yet to run it.
@Even: would it be possible to extract the "gdal-grass" as a separate tarball?
The existing one is too old:
http://download.osgeo.org/gdal/gdal-grass-1.11.2.tar.gz    06-Feb-2015
07:37     49K
thanks
Markus
