[gdal-dev] Using field name as variable in a "dialect sqlite" query
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 22 04:59:22 PST 2017
aborruso wrote
> Hi,
> I have this kind of CSV
> ID,x,y,epsg
> 1,500000,4000000,32633
> 1,500000,4000000,32632
> Is it possible to use ogrinfo and a "dialect sqlite" query in this way,
> and
> set the EPSG by reading the value from the `epsg` field?
> ogrinfo -dialect sqlite -sql "select ST_GeomFromText('POINT(' || x || ' '
> y || ')',epsg) from source" source.csv source
> If yes, how?
> Thank you
You can have only one SRID on a layer so you must either split your data by
the epsg field or transform each record to same SRID. Otherwise your request
was almost complete.
I wonder if anybody has tried to make SQL injection through the name of the
geometry column :)
ogrinfo -dialect sqlite -sql "select ST_GeomFromText('POINT('|| x || ' ' ||
y || ')',CAST(epsg AS integer)) from coords" coords.csv
INFO: Open of `coords.csv'
      using driver `CSV' successful.
Layer name: SELECT
Geometry: Unknown (any)
Feature Count: 2
Extent: (500000.000000, 4000000.000000) - (500000.000000, 4000000.000000)
Layer SRS WKT:
PROJCS["WGS 84 / UTM zone 33N",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AXIS["Latitude",NORTH],
        AXIS["Longitude",EAST],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",15],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","32633"]]
Geometry Column = ST_GeomFromText('POINT('|| x || ' ' || y || ')',CAST(epsg
AS integer))
OGRFeature(SELECT):0
  POINT (500000 4000000)
OGRFeature(SELECT):1
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
