[gdal-dev] Page Selection in GeoPDF in GDAL utilizes like gdalwarp, gdal_translate
Gane R gane.prog at gmail.com
Wed Nov 22 07:04:22 PST 2017
Thanks for your reply,
I got it working by referencing the the subsets like PDF:
On Fri, Oct 27, 2017 at 1:59 PM, <bradh at frogmouth.net> wrote:
> You should be able to just use the normal subdataset referencing. I like
> gdalinfo to get the syntax.
> Brad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171122/7369f5d6/attachment.html>
