[gdal-dev] report proj4 version to which gdal is linked?
Even Rouault even.rouault at spatialys.com
Sat Nov 25 05:47:29 PST 2017
> Thanks, that would match nicely, as rgdal already has bindings for
> GDALVersionInfo() but only uses "--version" and "VERSION_NUM" so far; our
> test for GDAL built with GEOS tests a fake union to detect success or
> failure.
Was available through the C++ API with OGRGeometryFactory::haveGEOS() but
I've now exposed it in GDALVersionInfo("BUILD_INFO") per
https://trac.osgeo.org/gdal/changeset/40832
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171125/470dd865/attachment.html>
