[gdal-dev] 4D netcdf-CF file with pressure as elevation
Edzer Pebesma edzer.pebesma at uni-muenster.de
Sun Nov 26 13:15:38 PST 2017
On 11/26/2017 07:10 PM, Even Rouault wrote:
>> I noted from the ncdump that the file has a time(time) variable with the
>> time values, but not a kz(kz) variable; instead it has a sigma(kz)
>> variable with pressure values which vary between 0 and 1.
>> Is this known behaviour?
> Edzer,
> I don't think so, but this is definitely a bug. I indeed see in the code
> that it assumes that if a variable is indexed by a dimension, there's a
> 1D variable of the same name that this dimension.
> Can you create a ticket about that ?
Sure: https://trac.osgeo.org/gdal/ticket/7165
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Edzer Pebesma
Institute for Geoinformatics
Heisenbergstrasse 2, 48151 Muenster, Germany
Phone: +49 251 8333081
