[gdal-dev] pass gdal dataset as an argument from Python to C
Sean Gillies sean at mapbox.com
Mon Nov 27 08:09:16 PST 2017
Shawn,
PyObject and GDALDatasetH are incompatible types and you can't pass the
former to a function that expects the latter. I'm surprised your program
can compile with these incompatible types.
Do you mean for your module to extend GDAL's Python bindings? If you look
inside the C code of GDAL's Python bindings you may be able to see how to
get the GDALDatasetH associated with a Python dataset object.
Hope this helps,
On Thu, Nov 23, 2017 at 1:25 PM, Shawn Gong <SGONG at mdacorporation.com>
wrote:
> Hi list,
> Has anyone done this before?
> I try to pass a gdal dataset as an argument from Python to C.
> in my C code, I have
> PyObject* py_my_func(PyObject *self, PyObject *args)
>     PyObject *poDataset;
>    if(!PyArg_ParseTuple(args, "Odd", &poDataset, &a1, &a2))
>     return NULL;
>   my_func(poDataset, a1, a2);
> void my_func(GDALDatasetH hDataset, double a1, double a2)
> Python crashed and hDataset was NULL
> Is it possible to do or I did something wrong?
> BTW, I have passed either a filename or a gdal array as an argument from
> Python to C, with success.
> Thanks,
> Shawn
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171127/ad9c0a3a/attachment.html>
