[gdal-dev] Build with MinGW in Linux
Even Rouault even.rouault at spatialys.com
Mon Nov 27 09:13:18 PST 2017
On lundi 27 novembre 2017 18:52:26 CET Ari Jolma wrote:
> My PR https://github.com/OSGeo/gdal/pull/265 currently fails on MinGW
> cross compilation and on Windows (AppVeyor) while running a test
> involving gdal.Translate (python code). The error is "ValueError:
> Received a NULL pointer." which is from the Swig bindings.
> How could I study the issue on my own Linux? I.e., how do I setup a
> MinGW cross-compilation setup, are there instructions somewhere? I could
> do that on a virtual machine but rather not in Windows. I've compiled
> years ago on MinGW but that was in Windows and it seems that
> cross-compilation (like Travis is doing) has improved lately.
For the mingw error, I guess you could reproduce the same with a non-curl enabled build (the
mingw targets do not have curl enabled)
wcs_6() lacks an introductory check:
if gdaltest.wcs_drv is None:
	return 'skip'
The MSVC/Appveyor failures are different and look like a segfault ( the AppVeyor target do
have curl enabled)
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171127/77f52e7c/attachment-0001.html>
