[gdal-dev] Building with support for VirtualOGR
René Hansen renehh at gmail.com
Tue Nov 28 04:09:29 PST 2017
Hi all,
As the subject reveals, I'm trying to compile with SQLite support, so I can
load libgdal.so as an extension, as per the example on
http://gdal.org/drv_sqlite.html.
I'm building with the Android NDK and it succeeds, seemingly fine, but when
I load the library as an extension:
sqlite3_exec(db, "SELECT load_extension('libgdal.so',
'sqlite3_extension_init');", callback, 0, &zErrMsg);
I get an error:
"SQL error: undefined symbol: sqlite3_extension_init"
I went looking for the definition of *sqlite3_extension_init*, and it
appears to be define guarded behind
"VIRTUAL_OGR_DYNAMIC_EXTENSION_ENABLED", so I tried to rebuild with that
flag set. This is my build script:
#!/usr/bin/env bash
set -e
export PATH=$PATH:`pwd`/android-21-toolchain/bin
export COMMON_FLAGS="-mthumb -DVIRTUAL_OGR_DYNAMIC_EXTENSION_ENABLED"
export CFLAGS="$COMMON_FLAGS"
export CXXFLAGS="$COMMON_FLAGS"
export LIBS="-lsupc++ -lstdc++"
./configure --host=arm-linux-androideabi --prefix=`pwd`/external/gdal
make
make install
Scanning the symbols in the produced .so, still doesn't include anything
*sqlite3** however:
$ nm -A install/external/gdal/lib/libgdal.so | wc -l
   56967
$ nm -A install/external/gdal/lib/libgdal.so | ag sqlite3 | wc -l
       0
I've really been scratching my head over this, so what am I doing glaringly
wrong?
Best regards,
René Hansen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171128/7d5b4293/attachment.html>
