[gdal-dev] Building with support for VirtualOGR
René Hansen renehh at gmail.com
Tue Nov 28 05:25:42 PST 2017
Jackpot. That was it!
It's amazing what kind of blindspots you can develop, setting up cross
compilations.
Now I'm wrestling with build errors related to jpeg and jpeg12, apparently
just disabling them with --with-jpeg=no and --without-jpeg12, breaks all
kinds of other stuff.
Alas, that is a different battle. Thanks Even!
/René
On Tue, 28 Nov 2017 at 13:28 Even Rouault <even.rouault at spatialys.com>
wrote:
> René,
> > As the subject reveals, I'm trying to compile with SQLite support, so I
> can
> > load libgdal.so as an extension, as per the example on
> > http://gdal.org/drv_sqlite.html.
> > I'm building with the Android NDK and it succeeds, seemingly fine, but
> when
> > I load the library as an extension:
> > I've really been scratching my head over this, so what am I doing
> glaringly
> > wrong?
> You don't have to manually define VIRTUAL_OGR_DYNAMIC_EXTENSION_ENABLED.
> The likely explanation is that configure fails to detect sqlite3. Did you
> check the output of the configure to see if there's a "SQLite support: yes"
> line arround the end ?
> You may need to add
> --with-sqlite3=/path/to/cross/compiled/sqlite3/installation/prefix
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171128/5de178ea/attachment.html>
