[gdal-dev] Question about command line options -append
Victor Chernetsky victor at amigocloud.com
Wed Nov 29 12:00:17 PST 2017
Hey Even,
How do I set OVERWRITE option?
I tried all these:
ogr2ogr -overwrite -f AmigoCloud "AmigoCloud:15276 datasets=100322"
~/Downloads/Visits.geojson
ogr2ogr --config OVERWRITE YES -f AmigoCloud "AmigoCloud:15276
datasets=100322" ~/Downloads/Visits.geojson
ogr2ogr -oo OVERWRITE=YES -f AmigoCloud "AmigoCloud:15276 datasets=100322"
In my driver CSLFetchNameValue( papszOptions, "OVERWRITE" ) is always NULL,
and DeleteLayer(int iLayer) never gets called.
How do switch ogr2ogr onto overwrite mode? Or how do I catch it in my
driver?
Thanks,
*Victor Chernetsky*
+1 (408) 368-4607
On Tue, Nov 28, 2017 at 4:26 PM, Victor Chernetsky <victor at amigocloud.com>
wrote:
> Thanks, this helps!
> The thing is I cannot really use layer name to identify an AmigoCloud
> dataset. In AmigoCloud we have names, but they are not guarantied to be
> unique. We use dataset Id to identify a dataset (ogr layer) instead. In my
> example "Visits" it's just a name of the source data file, which gdal uses
> as a layer name. This is fine, but for destination AmigoCloud dataset I
> specify a dataset id explicitly anyway. So I know my destination dataset,
> and if it exists or not. I think with the info I have now I could do few
> small changes to handle these cases.
> *Victor Chernetsky*
> +1 (408) 368-4607
> On Tue, Nov 28, 2017 at 4:01 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On mardi 28 novembre 2017 15:40:46 CET Victor Chernetsky wrote:
>> > Here is my example:
>> > ogr2ogr -overwrite -f AmigoCloud "AmigoCloud:15276 datasets=100056"
>> > I am trying to append, or overwrite data into existing dataset
>> > But it still created a new dataset, and it did not delete/clean old
>> > dataset.
>> -overwrite overwrite *layers* not datasets
>> Here it will probably create a new layer because the layer name of
>> Visits.geojson
>> must be "Visits" and probably doesn't exist yet in your dataset.
>> If you want to overwrite an existing layer foo with the geojson, you must
>> add "-nln foo"
>> > I am thinking I need to do something in
>> > my OGRAmigoCloudDataSource::ICreateLayer(). I am not checking if
>> dataset
>> > exist. I always create a new one.
>> You can have a look at the ogr2ogr logic to decide how to overwrite a
>> layer:
>> https://github.com/OSGeo/gdal/blob/trunk/gdal/apps/ogr2ogr_lib.cpp#L3180
>> For non-ogr2ogr clients, you could indeed add a check if a layer of same
>> name already exists
>> A number of drivers also support a OVERWRITE=YES layer creation option
>> See
>> https://github.com/OSGeo/gdal/blob/trunk/gdal/ogr/ogrsf_frmt
>> s/carto/ogrcartodatasource.cpp#L412
>> The advantage when you write an example is that you have tens of examples
>> to get inspiration from ;-)
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171129/a31e2680/attachment.html>
