[gdal-dev] Question about command line options -append
Victor Chernetsky victor at amigocloud.com
Wed Nov 29 13:33:17 PST 2017
Thanks, this worked!
I have a followup question: how does gdal/ogr2ogr knows that my destination
dataset/layer exists?
For instance, -append option suppose to do different things if layer
exists, or not. I don't see any isExists() APIs that would check it.
Thanks,
*Victor Chernetsky*
+1 (408) 368-4607
On Wed, Nov 29, 2017 at 12:02 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 29 novembre 2017 12:00:17 CET Victor Chernetsky wrote:
> > Hey Even,
> > How do I set OVERWRITE option?
> With -lco OVERWRITE=YES since this is a layer creation option
> > I tried all these:
> > ogr2ogr -overwrite -f AmigoCloud "AmigoCloud:15276 datasets=100322"
> This will trigger the logic at
> https://github.com/OSGeo/gdal/blob/trunk/gdal/apps/ogr2ogr_lib.cpp#L3180
> that first try to see if a layer has the same name as the input layer
> name, and if so call DeleteLayer() on it
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171129/29f23fd6/attachment.html>
