[gdal-dev] Possible bug with creating transactions using the FileGDB driver
mikeucfl mikeucfl at gmail.com
Tue Oct 3 12:47:17 PDT 2017
I recently stepped up some code to use Visual Studio 2015 and calling
GDALDataset::startTransaction(true) seems to fail for the FileGDB driver. I
tracked the issue down to cpl_conv's CPLCopyTree method:
In Visual Studio 2012 the first call to VSIStatL(pszOldPath, &sStatBuf) sets
sStatBuf so st_mode has the flags for a directory. The second call
VSIStatL(pszNewPath, &sStatBuf) fails internally because the new path
doesn't exist, and sStatBuf is remained untouched from the old path's call
(_wstat64 doesn't reset sStatBuf). This worked in favor for the next line in
CPLCopyTree since sStatBuf.st_mode is checked to see if the new path is a
directory (which it says yes because the old path is what set sStatBuf).
In Visual Studio 2015 _wstat64 clears out sStatBuf. So when VSIStatL is
called on pszNewPath, sStatBuf.st_mode doesn't show that it's a directory
and fails out saying "Unrecognized filesystem object : c:\temp\testing.gdb"
I'm thinking VSIStatL should check for a -1 response from _wstat64,
indicating the folder doesn't exist and VSI_ISDIR should only check the old
path's sStatBuf to see if it's a folder and not the new path (since it
doesn't exist at this time). Thoughts?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
