[gdal-dev] OGR2OGR WFS HTTP 504 but no ERRORLEVEL
Even Rouault even.rouault at spatialys.com
Tue Oct 10 05:07:52 PDT 2017
On mardi 10 octobre 2017 11:38:31 CEST Langford, Robert wrote:
> Hi Even,
> Thank you for looking at this and confirming.
> So would this fix be available in the next major release and if so does that
> have a release date currently?
Likely around May 2018
But if you build your own GDAL, you should also be able to backport the trunk changeset into
2.2 without too much pain:
https://trac.osgeo.org/gdal/changeset/40382
> In the meantime any thoughts on how we could programmatically pick up this
> error?
Perhaps redirect the standard error stream to a file and look for ERROR string in it ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171010/51ef195a/attachment.html>
