[gdal-dev] Fwd: [OpenJPEG] OpenJPEG v2.3.0 is out: more speed and memory improvement
Even Rouault even.rouault at spatialys.com
Fri Oct 13 12:48:10 PDT 2017
On vendredi 13 octobre 2017 15:32:11 CEST Matt Hanson wrote:
> Thanks guys, I got it to work from the 2.2 repo branch, which has the
> change on it. I could not get it to work with trunk.
Is pkg-config installed in your Docker env ? Can you share your dockerfile ?
http://www.spatialys.com
