[gdal-dev] vsicurl configuration design decisions
Sean Gillies sean at mapbox.com
Mon Oct 16 21:30:54 PDT 2017
Done: https://trac.osgeo.org/gdal/ticket/7095.
On Fri, Oct 13, 2017 at 4:29 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> > I'd like to point out that very often URLs in a query string do not need
> to
> > be encoded. Both the Python (see my earlier example) and Node standard
> > parsers will handle the string
> While researching that issue, and from my pat memories, I found that there
> is
> a bit of confusion around the subject when to escape or not
> > /viscurl?option1=foo&option2=bar&url=https://example.com/foo.tif
> > without any URL encoding.
> https://tools.ietf.org/html/rfc3986 says in "3.4.  Query"
>       query       = *( pchar / "/" / "?" )
>    The characters slash ("/") and question mark ("?") may represent data
>    within the query component.  Beware that some older, erroneous
>    implementations may not handle such data correctly when it is used as
>    the base URI for relative references (Section 5.1), apparently
>    because they fail to distinguish query data from path data when
>    looking for hierarchical separators.  However, as query components
>    are often used to carry identifying information in the form of
>    "key=value" pairs and one frequently used value is a reference to
>    another URI, it is sometimes better for usability to avoid percent-
>    encoding those characters.
> But urrlib.urlencode() encodes slashes in values of query arguments, so
> they
> probably decided to avoid isues with the above mentionned older, erroneous
> implementations
> >>> urllib.urlencode({'foo':'bar', 'url': 'http://example.com'})
> 'url=http%3A%2F%2Fexample.com&foo=bar'
> > The web already has escaping rules built in, one of the benefits I
> alluded
> > to above.
> OK, let's follow your suggestion of using URL query string formatting,
> while
> this hasn't gone in a official release. Could you create a ticket about
> that ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171016/7dc17290/attachment-0001.html>
