[gdal-dev] Error after building GDAL 2 in Debian jessie
aborruso aborruso at gmail.com
Tue Oct 17 00:39:24 PDT 2017
Hi Even,
thank you very much.
Even Rouault-2 wrote
> It looks you have at least two libsqlite3 installed on your system ? You
> built
> against one that has sqlite3_column_table_name available, but at runtime
> the
> dynamic loader finds one that has not it.
> You can use LD_LIBRARY_PATH to point to the path of the libsqlite3 that
> was
> picked up by ./configure
But I'm really a newbie.
I think I must add some option to "./configure
--prefix=/path/to/install/prefix [options]", but which option?
Is it something like "./configure --LD_LIBRARY_PATH =/path/to/libsqlite3"?
And a last stupid question: how to find the path of the installed
libsqlite3? With locate?
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
