[gdal-dev] WCS driver
Peter Baumann p.baumann at jacobs-university.de
Tue Oct 24 09:11:20 PDT 2017
FWIW, OWS Common 2.0 is known to be flawed in several aspects (we spec writers
suffered dearly - from the resources it needed to discover, to finding
workarounds in the spec, to explaining to people...). Trust me, the namespace
issue is just a minor one in comparison... OGC is looking to get something
revised since 2 (?) years now, and until that will come we will have to live
with this situation, unfortunately and sometimes painfully.
just 2 cents,
Peter
On 10/24/2017 04:07 PM, Ari Jolma wrote:
> Whoa! How hard can XML be? I have a real Capabilities document (from well
> known company) which defines *both* default and ows namespace to
> http://www.opengis.net/ows/2.0.
> Thus, to be sure, I need to look for *both* ows:ServiceIdentification and
> ServiceIdentification. Or maybe loop through all elements and check for both
> at each element?
> And additional spice is that in WCS 1.1.0 ServiceIdentification is in
> namespace http://www.opengis.net/wcs/1.1/ows. :)
> Ari
> Even Rouault kirjoitti 24.10.2017 klo 12:45:
>> > Is there any reason not to switch to libxml2 from minixml?
>> > I see only GMLAS driver uses libxml2 currently
>> Ah, yes indirectly when it validates the data/gmlasconf.xml file against
>> data/gmlasconf.xsd, since CPLValidateXML() uses libxml2 underneath to do that
>> (it could actually have an alternate implementation using Xerces-C validation
>> functionnalities.)
>> > , and maybe OGR VRT.
>> Same thing, OGR VRT, optionnaly, uses libxml2 to validate the .vrt file
>> against its schema.
>> But minixml functionnality should be enough for WCS purposes, and libxml2 and
>> Xerces-C remain optional dependencies.
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Peter Baumann
 - Professor of Computer Science, Jacobs University Bremen
   www.faculty.jacobs-university.de/pbaumann
   mail: p.baumann at jacobs-university.de
   tel: +49-421-200-3178, fax: +49-421-200-493178
 - Executive Director, rasdaman GmbH Bremen (HRB 26793)
   www.rasdaman.com, mail: baumann at rasdaman.com
   tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171024/8b4c10c1/attachment.html>
