[gdal-dev] GDAL and ESRI Compact Cache
Lucian Plesea lucianpls at yahoo.com
Tue Oct 24 16:17:11 PDT 2017
Not the whole cache, but with some effort you can read each bundle as a single raster, as long as they are V2 compact bundles.
The simplest method is to use the WMS driver.  Counter intuitive, I know.
With a recent GDAL, this XML WMS file reads a bundle at level 17 from my disk, as a 32768x32768 raster.
The default CS and coordinates are for GCS, they would have to be overwritten in the XML, via the correct DataWindow node.
<GDAL_WMS>  <Service name="MRF" type="bundle">    <ServerUrl>file://C:/RioG2/_alllayers/L17/R12100Cc100.bundle</ServerUrl>
  </Service></GDAL_WMS>
Lucian
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171024/cfec345b/attachment.html>
