[gdal-dev] About CMake build again
Dmitry Baryshnikov bishop.dev at gmail.com
Fri Oct 27 14:06:42 PDT 2017
As Even said it make sense to move discussion from this ticket
(https://trac.osgeo.org/gdal/ticket/7080) to the list.
First of all I would like to make small introduction to Borsch project.
Here it is some useful links:
    * Borsch repository: https://github.com/nextgis-borsch/borsch
    * Presentation on FOSS4G 2016:
    http://nextgis.ru/wp-content/uploads/2016/08/NextGIS-Borsh-presentation.pdf
    * GDAL repository adapted for Borsch:
    https://github.com/nextgis-borsch/lib_gdal
Shortly speaking Borsch is 3 CMake scripts which add ability to include
dependence library in one line of code.
It looks like:
find_anyproject(TIFF REQUIRED)
Certainly developer can add additional parameter to configure dependency
in find_anyproject function.
Inside  find_anyproject work 2 cases:
1. First of all (by default, but can be overridden) CMake searches host
system for dependency library (headers and lib files). This is usual
CMake find_package
(https://cmake.org/cmake/help/v3.0/command/find_package.html) with some
additional logic to try different options for hard cases (like Qt).
2. If library not found, find_anyproject can get the sources or prebuild
library from github.
So the GDAL or any other library can be build the normal way, but
developer have additional features to configure build all libraries with
one compiler and one set of compiler/linker settings (with some limits).
Such way we can have rather complicated scenarios to build GDAL and
dependencies.
Here it is several examples of benefits of this approach:
1. NextGIS Mobile SDK v3. SDK based on GDAL and need it in one library
for iOS as *.framework and for Android as *.so (arm7, arm64, i386,
x86_64 architecture). I build all dependencies include GDAL statically
and link in one fat library. The all code that do it:
https://github.com/nextgis/nextgis_datastore/blob/master/cmake/extlib.cmake#L118-L236
By the way the library also builds on Linux and Mac OS (Windows under
development) and CMake try to use existed in host system libraries. If
CMake find GDAL in host system it will use it and all
(-DENABLE_PLSCENES=OFF ... ) will be ignored as it already build with
another parameters.
2. Build GDAL Windows standalone installer and GDAL Ubuntu ppa:
https://github.com/nextgis/ppa/blob/master/gdal/master/debian/rules
3. Build QGIS
(https://github.com/nextgis/nextgisqgis/blob/master/CMakeLists.txt#L149),
(https://github.com/nextgis-borsch/postgis/blob/master/CMakeLists.txt#L165),
Formbuilder
(https://github.com/nextgis/formbuilder/blob/master/cmake/extlib.cmake#L53-L173)
This is main Borsch features.
There are some additional conventions like:
     * I modify all libraries included into Borsch repository to install
on unix-like paths. For Linux this is usual, for Windows and Mac OS this
let us to use Qt installer framework an install software mach similar
like on Linux. This is about target "install" which is vary on different
libraries (CMake has it own conventions about it). This is not mandatory
for Borsch itself but useful. CMake can register installed libraries in
system repository to simplify find them in find_package function.
     * CMake get library version from sources in all libraries included
into Borsch (if applicable, otherwise set it in CMake script). This is
necessary if exact version of library needed. This is not mandatory. One
more benefit during building process we can see dependency library
version in console.
     * We modify all libraries included into Borsch repository to find
dependencies using find_anyproject. It is simple to use libraries from
our borsch repository, but developer can fork them or use any other
sources and build systems to have dependency library in it's host system.
One can see this is all very flexible.
What about GDAL.
1. After unification GDALDataset and OGRDatasource current sources tree
is not fit for this new logic of GDAL classes. I rearranged sources more
closer to GDAL classes and CMake needs. Main changes are moving raster
and vector drivers inside drivers folder
(https://github.com/nextgis-borsch/lib_gdal/tree/master/drivers).This
simplify situation where different drivers need the same dependency
library (libpg, libsqlite, etc.). Also there are several raster/vector
drivers which need a separate directory but now presented in ogr or
frmts directories. There are some bad decisions I made - for example I
moved unit tests into separate repository - this was a mistake. We will
return unit tests back to GDAL repository.
An example of cmake friendly way see
https://github.com/nextgis-borsch/lib_gdal/blob/master/drivers/vector/CMakeLists.txt.
The driver developer must only create new folder and put CMakeLists.txt
file into it. The upper CMake script will find new driver and add it to
GDAL build. In common cases no need to modify upper CMake scripts.
2. I remove third-party code from drivers folders (TIFF, GeoTIF, PNG,
JPEG etc). All this code are in separate repositories. I don't see the
difference to get this code from git pull from main GDAL repository or
from the separate repository via find_anyproject process. Current GDAL
repository looks like the https://github.com/nextgis-borsch packed in
one repository.
In conclusion:
1. Borsch added flexible and useful features and not remove existing
approach
2. The current cmaked GDAL are in production in my company more than a
year on Windows, Linix, Mac OS, iOS, Android.
3. I'm ready to discuss and improve current solution. Any help are welcome
4. I also will be happy to contribute directly or via PR into GDAL trunk
instead of backporting in both directions improvements that we do in GDAL .
Finally:
Find the link to page with the CMake in GDAL discussion -
https://trac.osgeo.org/gdal/wiki/CMake
Best regards,
     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171028/45804550/attachment.html>
