[gdal-dev] WCS driver
Peter Baumann p.baumann at jacobs-university.de
Sat Oct 28 08:28:00 PDT 2017
FYI, this is one of the shortcomings of WCS 1.x. Remedied in WCS 2.
-Peter
On 10/28/2017 04:39 PM, Ari Jolma wrote:
> jratike80 kirjoitti 28.10.2017 klo 13:10:
>> Ari Jolma-2 wrote
>>> For example this request to a MapServer WCS (I'm not responsible for
>>> that server so don't know much about it), which is generated in the
>>> driver during a DescribeCoverage for the coverage,
>>> http://194.66.252.155/cgi-bin/BGS_EMODnet_bathymetry/ows?SERVICE=WCS&VERSION=1.1.1&REQUEST=GetCoverage&IDENTIFIER=BGS_EMODNET_CentralMed-MCol&FORMAT=image%2Ftiff&BOUNDINGBOX=9.833333335,46.183333325,9.837500005,46.187499995,urn:ogc:def:crs:EPSG::4326&RangeSubset=band
>>> gets the response
>>> WCS server error. Requested BBOX
>>> (46.183333325,9.833333335,46.187499995,9.837500005) is outside requested
>>> coverage BBOX (9.83125,30.01040372,22.23542659,46.18958333)
>>> If I change the order of X and Y in the bounding box in the request, the
>>> reply is ok.
>> Hi,
>> BoundingBoxes in WCS 1.1.x and 2.x must follow the axis order of the
>> coordinate system, so with urn:ogc:def:crs:EPSG::4326 it must be
>> latitude-longitude.
> ok, this is the famous confusion concerning axis order.
> To me it seems that GDAL is correct since it determines the bounding box
> originally from GridCRS in CoverageDescription where the origin is said to be
> "9.833333335 46.187499995" (i.e., lon-lat). In the same GridCRS the CRS is
> stated to be "urn:ogc:def:crs:EPSG::4326" - so the axis order could be assumed
> correct. Interestingly in the same CoverageDescription MapServer says the
> LowerCorner of the "urn:ogc:def:crs:EPSG::4326" BoundingBox is "30.01040372
> 9.83125" (i.e., lat-lon). So it seems to me that MapServer is contradicting
> itself.
> Reading MapServer code, it seems to be based on the idea that x,y is always
> east,north and when it writes BoundingBox, it swaps x and y if the projection
> is inverted (like 4326). It does not do that when it writes GridCRS.
> GDAL seems to be based on the idea that x,y is what the projection says (what
> the projection says could be found out with OGRSpatialReference::GetAxis -
> however, for 4326 it does not say anything). This is my impression from WCS
> driver - I see there's a lot on this issue in the GML driver page.
> A fix could be a WCS driver option "swap axis order for bounding box". But
> since I think that is not fixing the root cause (lying twice does not make you
> a truth speaker), also an option "swap axis order when reading GridOrigin" is
> needed. Isn't this fun?
>>   EPSG:3067 is natively an easting-northing system and
>> therefore it can make you believe that everything works fine but if you test
>> the Finnish services also with northing-easting system EPSG:2393 you may get
>> more frustration.
> I'm sure you mean 'fun'.
>> An open Geoserver with a DEM of Finland is available for testing at
>> http://avoindata.maanmittauslaitos.fi/geoserver/wcs?service=WCS&version=2.0.1&request=GetCapabilities
> I'll try the axis order with that. The geoserver at msp.smartsea.fmi.fi is
> mine and I'm not sure how well I can manage a geoserver.
> Ari
>> -Jukka Rahkonen-
>> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Peter Baumann
 - Professor of Computer Science, Jacobs University Bremen
   www.faculty.jacobs-university.de/pbaumann
   mail: p.baumann at jacobs-university.de
   tel: +49-421-200-3178, fax: +49-421-200-493178
 - Executive Director, rasdaman GmbH Bremen (HRB 26793)
   www.rasdaman.com, mail: baumann at rasdaman.com
   tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
