[gdal-dev] About CMake build again
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Oct 30 02:42:24 PDT 2017
Hi Mateusz,
If really "there is no plan or even will for such switch in GDAL" I
think nothing to discuss here.
The ticket #7080 should be closed and let's continue to live with
current developing approach.
Which solution, my or Hiroshi, will more popular show the time.
Best regards,
     Dmitry
30.10.17 12:24, Mateusz Loskot пишет:
> On 30 October 2017 at 10:06, Dmitry Baryshnikov <bishop.dev at gmail.com> wrote:
>> Also there is one big problem for me in #7080 - this is third build system
>> additionally to GNUMakefile, makefile.vc.  And now CMakeLists.txt must be
>> supported too. Three files which must be synced each other with and taking
>> into consideration the upper scripts, it's awful!
> Dmitry,
> This issue is orthogonal to actual CMake challenge.
> If core developers of a project X do not agree to switch to a new
> build configuration Y,
> then any initiative to develop setup for Y will live in a side car.
> AFAIU, there is no plan or even will for such switch in GDAL.
> Similar situation is with GEOS.
> Finally, developing configuration for Y build system by completely
> revolutionising structure of project X is a terrible thing to do in terms
> of potential switch to Y. IOW, the bigger and deeper a revolution, the less
> chance to get acceptance by core developers, also psychologically.
> Best regards,
