[gdal-dev] Crash using mem raster on Windows
Even Rouault even.rouault at spatialys.com
Mon Oct 30 13:36:48 PDT 2017
Andrew,
> I'm creating a memory raster using the following code:
> I read the three bands in succession.  This works fine on OSX/Linux, but
> fails when attempting to read the second band on Windows. Any thoughts on
> what might be the issue?
You need to use CPLPrintPointer() to format the pointer in a way
that will please the MEM driver
See https://github.com/OSGeo/gdal/blob/ddbf6d39aa4b005a77ca4f27c2d61a3214f336f8/gdal/alg/gdalcutline.cpp#L341
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171030/67bc8cc1/attachment.html>
