[gdal-dev] Open Jpeg 2.3.0 and OPJ_NUM_THREADS
N. Farah nfarah at hotmail.com
Tue Oct 31 12:39:23 PDT 2017
In http://gdal.org/frmt_jp2openjpeg.html under 'Thread Support' section there is the following:
"Starting with GDAL 2.3, this multi-threading at code-block level is automatically enabled by GDAL".
Was meant "Starting with OpenJpeg 2.3, ..." ?
If yes, was that enabling made in the 'OpenJpeg 2.3' library or was made in GDAL ?
Thanks
Noureddine Farah
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171031/19981e2c/attachment.html>
