[gdal-dev] Which Proj.4 transforms are available in GDAL?
Even Rouault even.rouault at spatialys.com
Fri Sep 1 12:05:04 PDT 2017
On vendredi 1 septembre 2017 20:42:34 CEST Andre Joost wrote:
> Am 01.09.2017 um 20:14 schrieb Even Rouault:
> >> ogr2ogr -s_srs EPSG:4326 -t_srs "+proj=lcc +lat_1=13.31666666666667
> >> +lat_2=14.25 +lat_0=13.783333 +lon_0=-89 +x_0=500000 +y_0=295809.184
> >> +k_0=0.99996704 +ellps=clrk66 +units=m +no_defs
> >> +towgs84=0,125,194,0,0,0,0 +wktext" LimitesNAD27.shp dptoA_WGS_1984.shp
> >> gdalsrsinfo LimitesNAD27.prj >>out.txt
> >> neither saves towgs84 or wktext
> > Yes, a .prj file contains a ESRI flavour of WKT, which supports neither
> > TOWGS84 or EXTENSION, so they get stripped.
And more importantly the original EPSG code is also missing in ESRI WKT.
> So how is a datum shift outside of the EPSG code world supposed to be
> applied to a shapefile with ogr2ogr?
You have to override the source SRS with -s_srs EPSG:XXXX if you know the code. One could
potentially improve the situation by trying to match the .prj CRS name with the entries in the
EPSG database to try recovering which code the ESRI WKT corresponds too (if there's a
match)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170901/7c1f45bd/attachment.html>
