[gdal-dev] git(hub) migration ?
Tamas Szekeres szekerest at gmail.com
Wed Sep 6 11:54:03 PDT 2017
I would also prefer to go for #3 if possible, though I don't have enough
experience how to make it happen.
Best regards,
Tamas
2017-09-06 15:14 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Hi,
> I've heard a few voices speaking/asking/begging for a git/github
> migration. At some point we'll certainly have to do it, as SVN vs git is
> beginning to feel more and more like CVS vs SVN 15 years ago.
> I can see different options :
> 1) migrate to git, and remain within the OSGeo infrastructure. This is for
> example the case of GEOS which uses the Trac git plugin and the GOGS (or is
> gitea?) git hosting (https://git.osgeo.org/gogs/geos/geos.git).
> gogs/gitea tries to replicate most github functionalities, but feature
> parity is still not there (you cannot comment on a commit e.g). We could
> still offer github as a mirror, which would ease contributions a bit
> compared to the current git->svn situation, but the "Merge" button from
> github couldn't (shouldn't) be used.
> 2) migrate code to github, accept pull requests (PR) directly there.
> Tickets still managed in Trac. But then we have no automated link between
> Trac and github (unless there's a Trac plugin for that). A few other OSGeo
> projects are in a similar situation: QGIS with Redmine for tickets and
> github for PR&code, GeoServer with JIRA for tickets and github for PR&code.
> I've some experience with the QGIS situation: Redmine can include github
> commit references if the git commit message includes the ticket number.
> But, of course, the other way doesn't work: from github UI, the #XXXX link
> doesn't work (or would point to a unrelated PR with same number). So this
> is middly satisfactory, and a regression from our current situation.
> 3) migrate code and tickets to github. I guess this would match most
> (especially occasional) contributor wishes regarding the "social" aspect.
> What would be needed is Trac -> github ticket migration. Thomas Bonfort did
> it for MapServer at some point, but he lost the script if I remember well
> (I can see in https://stackoverflow.com/questions/6671584/how-to-
> export-trac-to-github-issues a number of possibilities listed). One issue
> also is we have numbers taken by existing github pull requests, so there
> would be collisions on import (we could decide either to sacrifice
> colliding Trac tickets, as there are really old, currently the colision
> appear for tickets older than 2003, or move them to an available github
> ticket number. Or to sacrifice existing PR, but there are a few pending
> ones)
> There's also the valid concern about being tied with github.com regarding
> tickets. Recently I found https://github.com/josegonzalez/python-github-
> backup
> which can backup code, issues, pull requests, etc.. using the github API.
> Quickly tested it on their own repo. Seems to work (**), although a bit
> slow ( requires 2 GET per issue / pull request to retrieve extra details
> that are not retrieved by the global request you showed above). It has an
> incremental mode though which should make it efficient.
> My synthetic view of the situation:
> 1) is a pure free sofware & free hosting approach. Relies on SAC being
> appropriately man and machine powered (same as with SVN / Trac currently)
> 2) mixed solution. we still have ownership on all our data (code &
> tickets). but the separation between a ticket system and code+PR isn't
> ideal from a usability point of view
> 3) offers probably the best contributor experience. We loose a bit of
> control, but a backup(*) strategy exists (at least for now). I'd tend to
> favor this approach.
> I'm not sure if the current git mirror shouldn't be re-done from scratch.
> Its main drawback is that svn tags are reported as git branches, instead of
> git tags. I probably mis-configured things when I initiated the mirror a
> few years ago. Not completely sure this is worth the effort though. We can
> probably live with those existing mis-created tags, and use proper git tags
> for the future.
> The release procedure / script would also have to be updated. Probably
> other things too.
> There's also the question of the Trac Wiki, although this one might be
> defered for a later stage.
> So this email is mostly to say I'm open to the idea, but I'd appreciate if
> someone else could take the lead on this. I'd be happy to help. A RFC to
> formalize the move would be needed.
> Even
> (*) Backup might not be the inappropriate term, since this implies that
> you can easily restore things. If github closes or requires (insane) fees
> for open source projects, those saved tickets will have to be re-injected
> in some to-be-defined alternative, but at least their content is readable
> (json)
> (**) steps:
> 1) pip install github-backup
> 2) in github UI, create a personnal access token, so as to be able to use
> authenticated requests to github API, to bypass the rate limit of
> unauthenticated requests (you can use it even for repositories that you
> don't own)
> 3) github-backup -i -R python-github-backup josegonzalez --issues
> --issue-comments --issue-events --pulls --pull-comments --pull-commits -t
> ${your_github_token}
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170906/863dfaea/attachment-0001.html>
