[gdal-dev] Error while compiling gdal 1.9.2 in Ubuntu16.04
Farook farookrceg at gmail.com
Thu Sep 7 06:53:06 PDT 2017
I am trying to compile and build gdal 1.9.2 in Ubuntu 16.04.3. I am doing the
below steps
sudo wget http://download.osgeo.org/gdal/gdal192.zip
unzip gdal192.zip -d gdal
cd gdal
cd gdal-1.9.2/
sudo ./configure
make
When i run make, i am getting the below error
In file included from /usr/include/string.h:630:0,
             from /home/kcube/gdal/gdal-1.9.2/port/cpl_port.h:132,
             from /home/kcube/gdal/gdal-1.9.2/port/cpl_conv.h:34,
             from json_object.c:12:
json_object.c:29:9: error: expected identifier or '(' before '__extension__'
char* strndup(const char* str, size_t n);
GNUmakefile:23: recipe for target '../../o/json_object.lo' failed
make[4]: *** [../../o/json_object.lo] Error 1
make[4]: Leaving directory
'/home/kcube/gdal/gdal-1.9.2/ogr/ogrsf_frmts/geojson/jsonc'
../../../GDALmake.opt:539: recipe for target 'jsonc-target' failed
make[3]: *** [jsonc-target] Error 2
make[3]: Leaving directory
'/home/kcube/gdal/gdal-1.9.2/ogr/ogrsf_frmts/geojson'
../../GDALmake.opt:539: recipe for target 'geojson-target' failed
make[2]: *** [geojson-target] Error 2
make[2]: Leaving directory '/home/kcube/gdal/gdal-1.9.2/ogr/ogrsf_frmts'
GNUmakefile:51: recipe for target 'sublibs' failed
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory '/home/kcube/gdal/gdal-1.9.2/ogr'
GNUmakefile:56: recipe for target 'ogr-target' failed
make: *** [ogr-target] Error 2
Any idea how to solve this error? I badly needs gdal 1.9.2 compilation to
setup ECW suuport in geoserver.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
