[gdal-dev] fix build with poppler 0.58.0
Even Rouault even.rouault at spatialys.com
Fri Sep 8 04:39:41 PDT 2017
David,
Funny, because while you were sending this email, I was just working on this!, since someone
else reported the issue in
https://trac.osgeo.org/gdal/ticket/7033
Thanks for the patch. I've committed a changeset that is a bit a mix of your and my work (see
ticket). Note that your original patch fails to open PDF files at runtime (likely due to issues in
GDALPDFDictionaryPoppler::Get() / GDALPDFArrayPoppler::Get()). I've also added the
needed change in GDALmake.opt.in and in Windows makefiles.
You can check good behaviour of the PDF driver by running autotest/gdrivers/pdf.py and
autotest/ogr/ogr_pdf.py
I'd suggest packagers to run the whole testsuite (python run_all.py in autotest/) before
releasing their packages. There can be some occasional failures due to network issues, or
checksum differences du to slightly third-party lib version differency, but at least that can
give a picture if things are completely broken or not.
Even
> Hi,
> As a part of update of poppler to 0.59.0 in Fedora, I patched all
> depending packages to build with the new Object API. You can find the
> patch for gdal here:
> https://src.fedoraproject.org/rpms/gdal/blob/f17cd7bb3ffb6e141cb0335393bee9a
> 571f85b5b/f/0001-ad +apt-to-poppler-0.58.patch
> . Disclaimer: it is completely untested.
> D.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170908/5d2cd591/attachment-0001.html>
