[gdal-dev] Cloud Optimised GeoTiff format
Even Rouault even.rouault at spatialys.com
Fri Sep 8 09:46:22 PDT 2017
On vendredi 8 septembre 2017 09:35:33 CEST daunnc wrote:
> Haha, awesome!
> A bit more context: I think that it could be a great thing to query TIFFs
> directly (for instance) from AWS landsat bucket, and they already have
> generated .ovr files which can be used, probably an additional extra query
> would be not that bad. I didn't check segments ordering yet in their data,
> but I hope it can work.
The .ovr from landsat-pds are standard overviews, ie not ideal from a cloud-optimized point
of view. Their organization is : IFD1, IFD2, ... IFDn, data_of_IFD1 data_of_IFD2, ...
data_of_IFDn instead of the expected ideal IFD1, IFD2, ... IFDn, data_of_IFDn, ...
data_of_IFD2, data_of_IFD1 order that is a progressive rendering streaming friendly order.
That said, for most use cases where you just access to one resolution level, this is OK.
Another aspect into which the current script is really pedantic.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170908/b0f19d35/attachment.html>
