[gdal-dev] RFC68: C++11 compilation mode - Call for vote on adoption
Daniel Morissette dmorissette at mapgears.com
Fri Sep 8 11:16:22 PDT 2017
On 2017-09-06 12:14 PM, Kurt Schwehr wrote:
> Now that Tamas has added the msvc2015/2-17SDK's, I'd like to call a vote
> by the PSC on RFC68: C++11 compilation mode.
> The draft is here:
> https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
> -Kurt
+0
It's not clear to me that the benefits of the C++11 requirement justify
the potential trouble for those who have to support platforms with older
compilers. I do care about portability, it was one of the founding
principles of the project 20 years ago and I do not think that "stick to
GDAL 2.2" is an acceptable answer to the portability question. The fact
that other SDKs or apps may have the C++11 requirement is also not a
justification in my mind either for a core piece as important as GDAL.
That being said, I don't think I will be directly affected by the
change, and there seem to be enough contributors who are keen on dealing
with this that I do not need to worry about the problems and should not
block progress.
Daniel
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
